KDFE50A12U smudge on the screen?
Discussion in 'General TV Discussions Forum' started by rhysdean, Mar 22, 2006.
  1. rhysdean
    rhysdean
    Hi everyone got a KDFE50A12U delivered yesterday to replace my "broken" LG dlp rptv, but noticed that there is a mark on the screen just to the right of centre of the screen, it looks like a smudge or slighty darker patch about the size of a golf ball on the inside of the screen! :eek:
    Has anybody else has had the same thing on theres. I was wondering if this is normal or not before i call empire direct up to get a replacment. :(
    The only time i can see it is when the picture is dark or mostly red! :confused:
    Thanks in advance
    Dean.
  2. Dazzyman
    Dazzyman
    Aug 30, 2005
    1,073
    North Yorkshire
    +88
    Na it should be fine all across the board when its on. You get the illusion of a white patch in the middle when its off as thats light reflecting but on it should be perfect (Ive posted a load of pics in the get your pics out section on here for u to check).
  3. rhysdean
    rhysdean
    cheers for the reply but think its something to do with the IRIS function when i turn this down or off it dissapears.
    Lovely tv compared to the LG but may be because of the brightness.
    do get the white hase in the middle but this is when its on and its slightly to the right and up of centre. wierd but i can live with it now anyway.:smashin:
  4. DOG187
    DOG187
    Nov 1, 2005
    254
    +11
    no probs with mine either , may be a fault ??
