davetherave2
Now I have done a quick search on the forums and have seen others that have the same or similar issue that I have.
The problem seems to be that every so often about 30 - 45 minutes of using the HDMI connection the screen will go blank for a second or two and then come back to life.
this isn't too bad normally and I have only really noticed it recently as I generally used component or svideo on the TV. But I have test this with both my new 360 elite and a HTPC using a BFG 8800GTX and the same thing happens.
Is there a fix for this or is it a fault with the TV?
Other than this issue I have been loving this TV for the last 18 months or so and have been more than impressed with this fantastic set.
