KD32DX51 vs KV32CS70
Discussion in 'General TV Discussions Forum' started by aut0m0tive, Oct 13, 2004.
  1. aut0m0tive
    aut0m0tive
    Hi all, and apologies if this is a no-brainer of a first post...!
    Posting this on behalf of a friend, who is looking for a new 32" TV, from Sony if possible (to tie in with all the other AV kit).
    Just really wanted to know any pros/cons of either set, and what the general consensus would be. It will be a long-term purchase (won't change it for a good few years), so any future-proofness (apologies for my bad Englerish) would be a boon.
    Many thanks...
  2. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    It comes down to two things - does your friend get annoyed by flicker from 50Hz pictures (if yes, buy the CS70) and does your friend plan to watch digital terrestrial TV (if no to the first question and yes to the second, buy the DX51). If the answer is yes to both, I would suggest spending just a little more money on the 32DX200 (which is the TV I would buy if I could get a new one past The Purchasing Committee) But if he still can't decide, tell him to go for the one which will look best in his front room!
  3. fozzy73
    fozzy73
    hi,
    either tv is perfectly good. if u want 3 scarts of which 2 are RGB enabled then go for the cs70 if u want digital and dont have sky then go for the dx51. it toally depends on what u want to connect to the set. i personally would prefer the cs70 and for £599 off the web on www.digital-point.co.uk cant go wrong and ive always found them to be very good with delivery and customer service.
