KD-65X8505C vs XBR-65X850C input lag
Discussion in 'LCD & LED LCD TVs Forum' started by thewolfro, Jun 8, 2015.
Tags:
  1. thewolfro
    thewolfro
    Dec 22, 2009
    28
    3
    I am doing a research on the new KD-65X8505C and i could not find too much info about it.
    On the other hand it seem that XBR-65X850C model sold in US has a bit more info. are the two models mentioned above one and the same ? Comparing specifications on Sony website for both Europe and US it looks like it. If someone can confirm it would be great. I am quite interested in input lag measurements.
  2. albani
    albani
    Feb 6, 2008
    687
    4
    Antalya(TR)
    +53
    well sometimes and some series(models) may vary spec. on US !
    so if you live in UK then you should consider UK/EU spec. and info. etc.,
    ı think this ID X85x panel are same both side in EU and US imo
    Input LAG test;be carefull some off lag infos! they use to "LeoBudnar" method
    and its not given a proper and correct figures too!
    The correct measurement is with "CRT" Monitor!!
    for example with LB-test latency is 20 or 25ms but if you test with CRT then latency figure
    goes to correct value such as 35ms or 45/50ms!!
    ı never consider LB or any other test figures!
