Kapkirk
Weird thing happened last night, I have been using Kaspersky Labs Internet Security on my desktop for years with no issues, but seeing as it had only 20 days remaining on the Licence and with it being Russian owned I decided to remove it and use something else. I really can't trust it anymore, especially as I do online banking and loads of other financial stuff on it, and especially after this evening.
After removing it I found some of my private password files (normally zipped up and password protected itself) had appeared on my desktop, like they had been unzipped, this is simply not possible to do easily and by mistake. Some of the files that were open have not been used for at least 2 years so I would know if I opened them.
(The master password is not on the PC and is only known by me .. or so I thought. I also noticed my recycle bin was empty (it shouldn't be as I have not emptied them for about a week)
This begs the question, has this software been upto no good but hiding it until I removed it? The new Software I installed did not find anything bad like keyloggers, Malware or trojans but I am glad I removed it anyway. If you are using Kaspersky do you trust now?
