Kaspersky Anti-Virus for Free ! Worth £24
Discussion in 'Shopping, Deals, Discounts & Bargains' started by Gliese 581c, Jan 5, 2007.
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
  2. iGiDK
    iGiDK
    Aug 4, 2006
    971
    46
    Falkirk, Scotland
    +206
    Many thanks, my NOD32 sub is up this month so I might try a free AV suite in 2007 as I never had any issues at all last year with malicious software
  3. chief barker
    chief barker
    Mar 26, 2005
    1,882
    3
    116
    +864
    I'm going to give this one a large 'BUMP' it has saved me 20 quid as my anti-virus software licence had expired. I have been running this for a couple of days now without any problems whatsoever. Nice find. :thumbsup:
  4. chrisowe
    chrisowe
    Apr 17, 2003
    467
    Anywhere
    +16
    This would be good but I don't think it works with Vista, which I have installed.:(
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,974
    London
    +1,148
    I used to have this installed but recently replaced it with Avast. My personal experience was that I found it a bit of a resource hog. Personally, I'd recommend Avast or AVG for a free solution.
  6. chief barker
    chief barker
    Mar 26, 2005
    1,882
    3
    116
    +864
    In what way mate? having uninstalled F-Secure 2006 and installed this, I have found Kaspersky to be less intrusive and a system hog compared to F-Secure, which was less system intensive than AVG....well on my rig anyway.
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,974
    London
    +1,148
    If you finding it okay then stick with it. The other problem I had was there are compatibility issues with the Kaspersky engine and Logitech webcams - a further reason for me to go to Avast!
  8. lisa burrell
    lisa burrell
    error when loading into vista must be xp only maybe thats why there giving it away
    [email protected]~~
  9. mgirg
    mgirg
    Feb 4, 2006
    93
    +6
    I will take your advice and switch from f-secure 2006 to this as my subscription is up. Do you know of any good free firewalls and anti spyware programs?
    thanks
  10. chief barker
    chief barker
    Mar 26, 2005
    1,882
    3
    116
    +864
  11. Samantha
    Samantha
    Mar 10, 2002
    356
    im running on xp and i get error too.
    any ideas?
    thx
    sam
  12. swall101
    swall101
    Dec 29, 2004
    2,040
    +270
    I have Vista and use Kaspersky....... It is the best internet security programme I have used. Extremely user friendly, multiple updates everyday, totally the most UNobtrusive AV software I have used.
    Would recommend to anyone:smashin:
  13. mo786
    mo786
    Nov 12, 2006
    270
    +4
    Is the AOL version much different/crappy comapred to the proper version? can i downlaod the proper verion and use the same key? :D
  14. chrisowe
    chrisowe
    Apr 17, 2003
    467
    Anywhere
    +16
    No you can't, I tried that. The key only works with the AOL version.
  15. Nu Breed
    Nu Breed
    Aug 25, 2007
    97
    midlands
    +11
    As i understand it, the AOL version doesnt have 'LIVE SCANNING' available as a background process
    Yes, it is kaspersky because thats where it gets its updates, & as we all know, Kaspersky have the best anti-viral definitions available. period.
    i just hope there is no 'custom' spyware in AOL
    (BTW, avast has a reputation for throwing up false positives)
  16. chief barker
    chief barker
    Mar 26, 2005
    1,882
    3
    116
    +864
    It looks like AOL have pulled the plug on this one (follow the link in the first post) also my anti-virus has stopped updating the signatures, at least I had quite a few months free.
    I wouldn't recommend going with McAfee (as linked on the AOL page) even though it's free.
