karma karma karma kameleon
Discussion in 'Home Cinema Control & Remote Controls' started by Techtronic, Jan 1, 2005.
  1. Techtronic
    Techtronic
    Hi guys,
    I’m using a kameleon 6 in 1 remote control and am trying to program it using the magic learn feature from my old television remote. The first time I tried this it worked fine i.e. blinked twice after I entered 975 and sent it the infrared signal. However when I came to carry on the process the following day I now only receive one blink from the remote even through I is using the exact same procedure signalling an error might this are the batteries? Any suggestions would be most appreciated.
    Ian
    :lease:
  2. S Helton
    S Helton
    Oct 29, 2004
    81
    +4
    I think it means that the memory is full - the Kameleon can only learn around 50 commands before it runs out of space. If you are nowhere near 50 commands it might be the battery, but usually the display goes dim and lights all the 'buttons' when the batteries are running low.
