Karat AS 200 sub crossover setting
Discussion in 'Subwoofers' started by m1964, Jan 9, 2017.
  1. m1964
    m1964
    May 9, 2005
    45
    I decided to ask the question here before I turn my house upside down looking for the manual.
    If the sub is connected via a low-level input from my receiver, and the crossover frequency is set in the receiver (at 80 Hz), do I need to also set the crossover on the sub as well?
    I accidentally turned the crossover knob instead of the volume; I can't remember if the low-level input by-passess the crossover setting or not.
    I know it would be "safe" to set the sub to above 100 Hz bt I still would like to know.
    Thanks a lot.
  2. Violator
    Violator
    Jun 19, 2007
    1,698
    116
    Chester
    +557
    Set your sub crossover to max. Done :)
