Karaoke system? please help!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Gameplayers, Jul 10, 2005.
  1. Gameplayers
    Gameplayers
    Jun 19, 2005
    38
    Hi guys,
    ***Sorry if I've posted in the wrong section, i dont know which is the correct one for this topic. Feel free to move it to the right one please.***
    Anyway, I am after a decent karaoke system. Not just those pop idol cdg karaoke standalone system though.
    Currently all my karaokes are on DVD or VCD, and I use my current DVD player to play them. We have some karaoke mic but there is no plug on the DVD player itself.
    Any suggest on what to get to create a karaoke system please?
    I have been thinking of getting: -
    -A karaoke microphone system that handles 2 karaoke mic, wired/wireless
    -Speakers that would handle both the karaoke songs input from my existing DVD player, and also the input from the new Karaoke mic system.
    Please, I would be very grateful if anybody tell me exactly which and what to get? also where pls? and how much, LOL :D
    As for budget it would be after a £100 (its low...) but do let me know how much is needed and I will see if its worth it.
    Really, any suggestions for a karaoke system would be appreciated. :thumbsup:
    Many thanks all!
    Gameplayers
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    TBH I don't think you will get anything other than a 1 box solution within your budget :(
    with a quickl look around I came up with a £200+ system:
    www.maplin.co.uk
    200W Beginner PA Kit
    Product code: B01BF
    Price: £129.99
    Vocal Microphone
    Product code: YU37S
    Price: £24.99
    4-Channel Mono Mixer
    Product code: MY95D
    Price: £17.99
    but the above does not include any form of reverb/echo that is a must for karaoke! Therefore you may be better off spending more on the mixer and getting something like:
    MMX-410 Pro Mixer
    product code: L54AN
    price: £79.99
    by the time you add in any additional cables etc you wont be far short of £300.
    Mark.
  3. Gameplayers
    Gameplayers
    Jun 19, 2005
    38
    what can the Pro Mixer do? and if i get the pro mixer what else do i need to purchase?
    at the moment i have dvd player & karaoke mic.
  4. Mark_a
    Mark_a
    May 27, 2005
    2,866
    +485
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    MMX-410 Pro Mixer Manufacturer: ProSound
    • 4 channel stereo mixer
    • 2 mic inputs with echo feature
    • Eight built in sound effects
    • Crossfader with channel selectors
    • 7 channel EQ
    The PA starter kit, cables, speaker stands etc etc
    If you have leads and don't want speaker stands etc then it's just the pro mixer and the PA starter kit at around £210. Everything else can always be bought at a later date as funds allow, if required!
    Mark.
  6. Gameplayers
    Gameplayers
    Jun 19, 2005
    38
    any other suggestions would be much appreicated :)
