Kameleon4 For Panasonic Dvd Rec
Discussion in 'Home Cinema Control & Remote Controls' started by Baron Von Doom, May 12, 2005.
  1. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,519
    worthing
    +135
    Will My Kameleon Urc-8040 Control My Dvd Recorder Panasonic Dmr 55. Would This Be Done With A Vcr Code
  2. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,519
    worthing
    +135
    ANYONE :lease:
    CANT GET IT TO CONTROL IT. SHOULD I TAKE REMOTE BACK AND GET THE NEW VERSION
  3. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    Phone OneForAll customer services 0808 1000 306. Ask them if they know the code for your DVD recorder - they might ask you to send your controller to them so that they can add the code. Alternatively, learn the codes from your Panasonic remote - should be explained in the manual.
  4. dodgydaz
    dodgydaz
    May 17, 2005
    411
    Nottingham
    +10
    Ring the number in the manual. If you have tried all the codes and it still doesnt work, you can call the number, and they will send the code down the phone. The Kameleon has a built in modem so are potentially future proof.
