Kameleon won't work my amp
Discussion in 'Home Cinema Control & Remote Controls' started by dmjohnson123, Jan 4, 2003.
  1. dmjohnson123
    dmjohnson123
    Nov 25, 2002
    265
    Wetherby near Leeds
    +5
    Just received my gorgeous Kameleon 6 today. It works my TV, DVD and Video no problem but it won't work my Sony AV amp :confused:.
    I have a Sony STR-KSL5 (its the amp that comes as part of the HT-SL5A amp/speaker bundle).
    I have tried downloading the Tuner/Amp - Sony 1, 2 and 3 upgrade files from the oneforall website all to no avail.
    The original Sony remote that came with the amp is labelled as the AV SYSTEM3 and also RM-U25.
    Anyone got any ideas or experience of similar problems.
  2. flat spot
    flat spot
    Dec 30, 2002
    407
    +34
    I've just got one and have now got it to work my sony strdb780. I think you can ring a helpline and they can help you set it up:D
  3. dmjohnson123
    dmjohnson123
    Nov 25, 2002
    265
    Wetherby near Leeds
    +5
    Thanks for the reply flatspot,
    I phoned the helpline today and they sent an upgrade through the handset - clever stuff.
    Everything is now working :D - just got to set up a few special function keys - I'm off to play :p
