Kameleon Remote and Marantz SR5400
Discussion in 'AV Receivers & Amplifiers' started by ajt, Jul 29, 2004.
Tags:
  1. ajt
    ajt
    Jul 29, 2004
    24
    Hi All,
    This is my first post here so go easy on me!
    I'm in the process of building my first proper AV system and am looking at an amp like the Marantz SR5400. Richersounds have some good deals on eBay but the units don't have remotes. I imagine this is a bit of an issue for an AV amp. However, I have the oneforall Kameleon 6 remote. Has anyone used one of these with a Marantz, or any other for that matter, amp? Do you get enough functionality or do I really need the original remote?
    Thanks for your help.
    Andy
  2. Radiohead
    Radiohead
    Dec 24, 2001
    4,396
    Amazingstoke
    +432
    I tried a Kameleon with my old SR7200 and it struggled with switching between inputs where the amp needs 2 presses of the input button to change over.
    I'd say your best bet is the Marantz RC1400 which will control the amp out of the box for you.
    Available here http://www.avland.co.uk/marantz/rc1400/rc-1400.htm
  3. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    I have the Kameleon for my Sony amp. On the initial set up it didn't do a great deal of the functions, but with the teaching you can get it to learn a few of the heavily used functions.
    Day to day use is absolutely fine, as the only things I do are volume, input and sound processing. I just keep it in the cupboard incase I need it!
