kameleon & Pana Home cinema??
Discussion in 'Home Cinema Control & Remote Controls' started by sjnolloth, Feb 3, 2003.
  1. sjnolloth
    sjnolloth
    Would like to get the Kameleon but would like to know whether it would work with the Panasonic DVD Cinema kit that i have.
    Any body got one that works with their cinema package or has any info on these?
    Looked on their site but couldn't really find much.
    thanks
    steve
  2. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    Can you tell us what kit you have? That might help ;).
    Anyway, I have a Panasonic A150 DVD player and a 28" 4:3 TV (can't remember the model number), and it works them both OK.
    Hope this helps :).
    Regards,
    Dave.
  3. sjnolloth
    sjnolloth
    Its a Panasonic DVD stereo system(sa-pm08),
  4. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    I'm sure it will as I have just bought one of these little beauts and it works my Philips HCS.....You may have to do a bit of manual remote learning but I have configured mine to work:
    Sony tv
    Panasonic digibox
    Panasonic VCR
    Philips DVD HCS
    Sony Audio seperate set up
    Splash out you won't be dissapointed:smashin:
  5. sjnolloth
    sjnolloth
    where did you find the codes for your HCS?
  6. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    Before I bought it I e-mailed OFA and they gave me the code for the device but it took 4 weeks for the reply so just as well that i was in no rush:boring: Anyway it makes no odds the code was in the book they supply unde3r audio device just one word of warning you may have to split the HCS controls betwen the DVD selector and the Audio device as the keys are a little limited on the audio device. I done this and configured the CD function to operate my sounds system......if for whatever reason it won't all work its no prob as you can teach the Kameleon the functions or contact OFA to program over the phone......I had exactly the same concerns as you have ........i've only had the Kameleon since Friday and it is well worth the 70 motes ........5 redundant remotes!!!=== more armchair space:clap:
  7. sjnolloth
    sjnolloth
    thanks for all your help,just ordered one from dixons!
    steve
  8. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    Post what you think when you get it
  9. gingerone
    gingerone
    Dec 10, 2002
    2,416
    +305
    I'm interested in this remote as it is the only one that works with NTL digital, anyone actually tried it with NTL?
  10. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    gingerone,
    I have managed to use it with NTL digital. I have the Pace model 1000 STB, and it worked straight away once I'd put in the appropriate Pace STB codes. The only thing I had to do was to program a button to do the 'Browse' feature, as it appears that function isn't implemented as standard by the Kameleon. However, this was simple - enter the learning code, point the two remotes at each other, press 'Browse' on the Pace controller, press the button you want it on with the Kameleon (I used 'Info' as it seemed most appropriate), and you're off :). Couldn't be easier!
    I'm very impressed with this remote, as it's proving very easy to set up and use - thoroughly recommended!
    Regards,
    Dave.
  11. jpfrost
    jpfrost
    Jan 18, 2003
    93
    Just purchased this remote and wonder how you don things like "Counter reset" and switch between "Clock/ Counter" on the VCR??
  12. sjnolloth
    sjnolloth
    Finally got one,lives up to all my expectations!
    Easy to use and setup.
    thanks for all the replies.
    steve
