Kameleon and Pace ntl cable box
Discussion in 'Cable TV & Virgin Media TV' started by digitaldave, Jan 28, 2003.
  1. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    I've just picked up a Kameleon, and so far I'm very impressed. I've got most things working OK, but there's something I need help with...
    My current Pace ntl handset has a button marked 'browse', which brings up a bar at the top with the time, channel, current program etc., and at the bottom, there is a list of upcoming programs for that channel that you can scroll through. However, I can't get the Kameleon to reproduce this function :(.
    Does anyone know if this is available? I've used the code '1060', as '1068' didn't do anything, and the cable box is a Pace 'DITV1000', according to the user guide, if that helps.
    Thanks,
    Dave.
  2. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    Have you tried to teach the remote the fuctions via the 'learn' ability?
  3. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    No, I haven't tried the learning ability yet - that was going to be my next step :). I was hoping that there would be a button aleardy programmed ;).
    Cheers,
    Dave.
  4. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    Sorry can't help you as I haven't got a similar box.
    However I can recommend that you teach it the key.
    I have had to 'teach' any non-standard keys to my kameleon (remember that you can overwrite pre-existing ones which can be useful.)
    The browse button I would imagine is non-standard so the 'learn' ability is probably the only way to go.
    I find it very good & it learn't all I threw at it. ;)
  5. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    mdou,
    I've just used the learning feature to add the 'browse' button from my existing handset - worked like a charm, and easy too :). I love this remote!
    Thanks,
    Dave.
  6. Cornelius
    Cornelius
    It really is manna from heaven for all those with frigging pace/NTL IrDA boxes!!
    CKA.
