Kameleon 8 Code for SKY+
Discussion in 'Home Cinema Control & Remote Controls' started by Diesele, Sep 19, 2004.
  1. Diesele
    Diesele
    I thought I had the correct setup code for SKY+ control as it is listed on One For All's website as 1175 for Kamelon 6, but it doesnt work my box...
    I also noted that since the Kamelon 8 is an US import the codes for Toshiba TV's (for e.g) are completely different. This makes me think that there are big differences in setup codes between US or/and Kameleon 6 [UK vers] controller.
    ANYWAY! Anyone know the correct code for SKY+ on a Kamelon 8?
  2. no_idea
    no_idea
    try the JP1 website
  3. Brian@ThePark
    Brian@ThePark
    No code for Sky+ on Kameleon 8. It is a US remote and doesn't have a code in memory. JP1 is the only way.
    Brian
  4. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    Use the learning feature.
