kameleon 6
Discussion in 'Home Cinema Control & Remote Controls' started by GuitarGray, Jan 17, 2003.
  1. GuitarGray
    GuitarGray
    anyone got 1? any advice for me i would like 1 (i think) i have dvd 2 tvs sky and a video so it should work them all shouldnt it? and does the internet download upgrade thing work??
    thanks
  2. russ331
    russ331
    Dec 30, 2002
    634
    28
    +88
    The kameleon should do what you want, but so too will the One For All 6 (URC-7562) at less than £30.
    Cheers,
    Russ
    London
  3. Browner
    Browner
    Got the Kameleon for xmas, excellent and very cool :cool: .
    The internet download is a loose description, you log on to the website find any codes that are not supplied (supply a large number in manual), then hold the remote next to PC speaker and it plays a wav file that updates your remote.
    Anyone got the setup code for the Arcam DV88?? Have been lazy and not phoned their support line yet.
    Very easy to set up, feels nice and even the wife can use it.
    HTH
  4. dmjohnson123
    dmjohnson123
    Nov 25, 2002
    265
    Wetherby near Leeds
    +5
    I'd 2nd that Browner. I got my Kameleon 6 just after xmas and have been very impressed.
    In fact its revolutionised my life - I no longer spend 10 minutes finding the original remotes which the kids have hidden before watching a DVD.
    It should do everything you need to do Guitar Gray and I have used their customer service upgrade over the phone which worked like a dream.
    In my experience their customer service was excellent and I'd say go out and get one !
  5. GuitarGray
    GuitarGray
    ok im sold sent for it now a few days wait dixons online only £59.99 so i will save a tenner to get a new dvd with :)
    thanks for your input..
    Gray
