Kameleon 6 (URC-8060) Help needed!!!!
Discussion in 'Home Cinema Control & Remote Controls' started by Tase, Mar 13, 2005.
  1. Tase
    Tase
    Hi there,
    I really have a problem with my Kameleon 6. I own the RC since aprox. 6 moths, and I've never had any problem.
    Since I "zapped" blind once (I don't know exactly whitch button I hit - close to the "OK" Button I guess), all buttons are flashing up and I can't stop it. I can't do anything. I removed the batteries over night. I tried to delete alle the functions, to get a "fresh" setup. But I can't do anything!!
    Do you habe a cloue?
    Greetings from Germany
    Tase
  2. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    Sounds like it's dead. I'd contact OneForAll customer services - I'm not sure what you would dial from Germany though - their customer service is excellent. They'll probably ask you to send your remote to them and they would replace it. Good luck.
  3. ranar
    ranar
    Mar 28, 2003
    123
    London
    +7
    I do know that a symptom of batteries running out is all the keys flashing up and staying on for sometime. I know you removed the batteries overnight - but did you try ne batteries as well??
  4. Tase
    Tase
    Hi and thanks for your answers.
    I solved the Problem!!!
    @ranar, the batteries were empty befor and the RC didn't word at all.
    But now I had new symptons....
    Anyway - Ofcause I changed the batteries befor, but I don't know how old there are. So I just got 4 new batteries today. What should I say? IT WORKS! I guess, the batteries I haved changed were to old/week, so I had the same symtoms! May it were the brand of the batteries??? I'll check that out and let you know!
    Thanks guy's....
    Tase
  5. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    S**t advice from me then - :rolleyes:. Ranar, I am humbled in the presence of your superior knowledge.
