Kameleon 6 owners
Discussion in 'Home Cinema Control & Remote Controls' started by jpfrost, Feb 8, 2003.
  1. jpfrost
    jpfrost
    Jan 18, 2003
    93
    I have just pruchased this remote, and overall finding it very good. However, sometimes when i pick it up the "auto on" function does not work - i have to press a button for it to light up.
    Do you think this is a fault with the unit or does this happen for a reason?
  2. bobbles
    bobbles
    how many buttons/macros can it learn?
  3. flat spot
    flat spot
    Dec 30, 2002
    418
    +34
    I think it is a fault. I have one, and if you so much as blink it lights up. [​IMG]
  4. bobbles
    bobbles
    got one now auto on is very responsive
    mine does buzz when on though
    one minor annoying feature is that you can not learn on all the buttons
    say for example on my DVDR there are quite a few features i need to learn but on the dvd buttons not many are lit up :mad:
  5. bobbles
    bobbles
    do your Kams buzz when on
    I am finding this quite annoying, is it normal?
  6. Cornelius
    Cornelius
    this is normal.
    Just tun up the volume.
    CKA:smashin:
  7. jpfrost
    jpfrost
    Jan 18, 2003
    93
    Has anyone tried to ring the Customer Support Line?
    I am trying 0808 10000 306 and it rings threes times then goes dead?
  8. Browner
    Browner
    The auto on is very sensitive, however I have just changed first lot of batteries since Xmas. It became alot less sensitive when batteries nearly drained.
    As for the buzz, not an issue, only hear it when deadly silent.
  9. pwhite8314
    pwhite8314
    Jan 4, 2003
    117
    16
    Fort Worth
    The buzz (it's more of a whine/whistle) is related to the brightness of the panel - turn it down, and the pitch reduces.
    Still just as noisey, but useless information is always good to know ;)
  10. Cornelius
    Cornelius
    I don't know wether its me or not but does the sensitivity reduce as well when reducing the EL backlight???
    CKA.
  11. JimNoble
    JimNoble
    Aug 2, 2002
    63
    Hemel Hempstead
    +7
    Well, here we are nice months after this post, and I just phoned the above number (as per the ofa website) - got through to a cab company in (judging by her accent) scotland. Although mildy upset, she did kindly point out that the number should be 0808 1000 306 - I guess it's not the first time that's happened... :)
    Nice to see they've corrected it... NOT!
    Jim
  12. bobbles
    bobbles
    i do like the remote but it is really greedy on the batteries
    I am using decent quality batteries on the lowest brightness setting yet I still have to change them each month
    expensive remote long term
  13. cdave
    cdave
    Dec 10, 2002
    306
    What size of cell does it take and how many. I was going to replace my one for all 6 with one of these but if it is that greedy I am not so sure. :eek:
  14. bobbles
    bobbles
    4 AAs personally i am thinking of upgrading to a home theatre one
  15. DaveP
    DaveP
    I'm a bit confused by this. This is the second time I've seen reference to using AAs. Mine takes AAAs and they don't rattle!
    Are there two different models?
    Dave
  16. MarkR
    MarkR
    May 3, 2003
    1,849
    Somewhere in Kent
    +299
    Just for reference it is normal for the buzzing noise.
    If you goto there website and goto to FAQ there you will see that the buzzing noise is normal. :zonked:
  17. bobbles
    bobbles
    my fault 4 AAAs
    they are a bugger to replace too
