Kameleon 6 and X10?
Discussion in 'Home Cinema Control & Remote Controls' started by uksteve69, Oct 22, 2003.
  1. uksteve69
    uksteve69
    Jul 16, 2003
    70
    Telford
    I have the Kameleon remote and have set it up for X10 using the code from the manual. I am using the IR7243 controller to operate just a light at the moment.
    The problem is I can only use the remote when it is about a foot away from the controller and directly in line with it.
    Does anyone else use this setup or know why I have such a limited range and angle?
    I have phoned simplyautomate who think it is a problem with the remote as they have heard of the same problem with the Kameleon remote.
    Anyone help??
  2. KW1816
    KW1816
    Jun 14, 2002
    836
    Surrey
    +14
    Is the IR7243 near sunlight ?
    I seem to remember they're quite sensitive to it.
    Of course if it's dark and you get the same problem then ignore the above :D
    Kevin.
  3. uksteve69
    uksteve69
    Jul 16, 2003
    70
    Telford
    KW1816
    It happens in the dark aswell!!!
