Kameleon 6 and Wharfedale 750
Discussion in 'Home Cinema Control & Remote Controls' started by jpfrost, Feb 7, 2003.
  1. jpfrost
    jpfrost
    Jan 18, 2003
    93
    Anyone know of a code to get this working?
  2. clearys
    clearys
    Dec 16, 2002
    120
    Sheffield
    +9
    Don't know it off hand but go to the 1forall website, download the new code and away it goes. got the same DVD and worked first time for me.
  3. jpfrost
    jpfrost
    Jan 18, 2003
    93
    I've tried that, and that didn't work.
    I have also called the support line and they give me some other updates
    One did have some effect but all the buttons were performing the wrong tasks. They told me send them a picture of the remote so they can check it is the same one as the codes are for.
    Is this what yours looks like?
  4. clearys
    clearys
    Dec 16, 2002
    120
    Sheffield
    +9
    Mines different to that - I got the first model that came out with the small black remote with the very cr@ppy buttons. Didn't work till I downloaded new file and used one of the codes supplied with it. All my functions work now.
    Sorry mate.
  5. Boink!
    Boink!
    Oct 5, 2002
    598
    +34
    I have one of the original 750's and have not been able to get it working with my Kameleon. :mad:
    I will try their website this evening!
    Thanks,
    Jon
  6. Boink!
    Boink!
    Oct 5, 2002
    598
    +34
    I'm not going to have to bother with the Wharfedale as I have just bought a Pioneer DV-656a instead. Well it was payday! :smashin:
