Kameleon 6-1 and Toshiba RDXS32
Discussion in 'Home Cinema Control & Remote Controls' started by dnesdlrow, Oct 21, 2004.
  1. dnesdlrow
    dnesdlrow
    Aug 17, 2004
    13
    Does anyone know if the Kamelon will operate the RDXS32?
    When I try using the Toshiba codes all that happens is I get 'DR-1' displayed in the Tosh's front panel.
    Now what the hell does that mean?!
    Thanks.
  2. kdp99
    kdp99
    Mar 29, 2001
    205
    Southampton,Hants,UK
    +23
    I got a much older one for all to work my RDXS32 using a JP1 file, this was created for another Toshiba DVD recoder but worked fine, I would be shocked if it did not work yours.
    The JP1 set up code was 1503.
    You can find it here
    http://groups.yahoo.com/group/jp1/files/3. Device Codes/DVD/
    As to your JP1 question I do not have a Kamelon, but understand it does do JP1, but it does not have the connector, so needs to have the jp1 connector soldered on.
    Have a look here
    http://www.hifi-remote.com/forums/viewforum.php?f=3
    Keith
  3. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    you could spend ten minutes teach the remote.
    Gary
  4. kdp99
    kdp99
    Mar 29, 2001
    205
    +23
    Problem is using learning that mosytOne for all remotes have a limit of about 25 learnt commands, - fills up very easily, so unless the remote is a pure learning remote use learning as a last resort.
    Keith
  5. dnesdlrow
    dnesdlrow
    Aug 17, 2004
    13
    Thanks guys,
    I feel a Pronto coming on.
  6. The Robman
    The Robman
    You don't need to modify the URC-8060 to get it to work with JP1 (and in fact there isn't a mod available), what you need to do is get a pogo-pin adapter which costs about $10 US. You could also call OFA and ask them to load the code for this DVD player over the phone, the code is DVD/1988
  7. pantages
    pantages
    Jan 7, 2004
    944
    2
    Boston
    +59
    I had a Pronto and loathed it! I now have a Kameleon 6 and love it! It is easy to use, clear to see and easy to program. The answers to previous questions can all be found in the manual.
