Kameleon 2nd Gen 6 in 1 for Sony DAVS 880 HCS
Discussion in 'Home Cinema Control & Remote Controls' started by JimmyT, Apr 8, 2005.
  1. JimmyT
    JimmyT
    Apr 8, 2005
    216
    +9
    Does any have the code for the Sony DAVS 880 HCS for the 2nd Gen Kameleon 6 in 1 (or any tips if the code is not available).
  2. RST
    RST
    I managed to get basic functions working with the Kameleon and asked them for some help. They gave me the following info for my DAV s880 - hope it helps. Its a lot to enter but I'm hoping to try and programme the kameleon via jp1 - it has the 6 pin connector there in the battery compartment although I've heard that the hardware doesn't function on the European model.....:(
    "To program the missing functions onto your One For All, please find below the full function list for the tuner code1858 (the correct code for your Sony unit).
    The functions can be programmed using the following procedure:
    1. Press and hold down the Hat key until the rabbit
    appears
    2. Press KEY MAGIC
    3. Press the TUNER key once
    4. Press the HAT once and let go
    5. Enter the code for the required function (please see bellow)
    6. Press the One For All key you wish to
    assign the function to, the IR indicator will blink twice
    7. Press ESC to quit or KEY MAGIC to program another function
    Your functions code are:
    > 51150 -/-- 29647 Display 27342 Preset Down
    51150 >10 39836 DVD Display 26318 Preset Up
    50894 0 66716 DVD Menu 27342 Previous
    19150 1 01180 DVD Menu 43932 Repeat
    50894 10 38044 DVD Setup 51612 Return
    18126 2 64462 Enter 27598 Search Forward
    18638 3 44750 Function 25806 Search Reverse
    17614 4 49615 Memory 26780 Select
    19406 5 63182 Menu Down 27598 Slow Forward
    18382 6 63694 Menu Left 25806 Slow Reverse
    18894 7 62670 Menu Right 45518 Sound Field
    17870 8 64206 Menu Up 40910 Stereo/Mono
    51918 9 33743 Muting 60060 Stop
    28110 Amp Menu 70862 Name 13468 Subtitle
    14236 Angle 05326 Name 43676 Time
    15260 Audio 26318 Next 67740 Top Menu
    48591 Band 35228 Open/Close 02204 Top Menu
    50588 Clear 59036 Pause 25806 Tuning Down
    52174 Digit Enter 26780 Play 27598 Tuning Up
    53199 Dimmer 42140 Play Mode 31951 Volume Down
    58780 Disc Skip 32719 Power 32975 Volume Up"
