Kameleon 10 - URC 8210
Discussion in 'Home Cinema Control & Remote Controls' started by Malkyboy, Jan 20, 2005.
  1. Malkyboy
    Malkyboy
    I've read the threads on the Kameleon 6, but has anyone used the Kameleon 10? How does it compare to the Harmony which is mentioned in some threads?
    Also, from the www.oneforallkameleon.com website the 10 appears to come with RF Transmission for multi room. Does anyone know if this is any good and if you are able to add additional receivers to use in third and fourth rooms?
  2. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    I'm not sure that the Kameleon 10 is available yet.
