Kalibrate's Advertiser Thread - Take a look for information, offers, news etc.
We are experiencing some issues, with our website (slowing down), caused by the host. We are looking at resolving ASAP, but in the meantime we wanted to introduce PSA (Power Sound Audio) subwoofer. Utilizing twin 18" active drivers and a 1700W Class D Power Amplifier, this has the potential to cause a real rumble at under £2,000 for one, and under £3,700 for two. They are supported by the customary 5 year warranty.
The S3600i offers an unheard of value in the audio industry. Dual high efficiency 18" drivers, a conservatively rated 1700W amplifier with ICEpower® sound technology, and a brand new dual opposed enclosure that relies on Newton's third law of motion to completely cancel all reactive energy. The end result is a subwoofer that extends into the single digits in all but the largest of rooms, offers vision blurring mid and upper bass capabilities, and does all of this while remaining completely inert.
FEATURES
Two, USA built, proprietary 18" drivers with powerful motor strength and efficiency.
Patented digital ICEpower® 1700W amplifier with DSP control
CNC precision cut cabinets that are finished in our industry exclusive satin black texture
17Hz-200Hz +/-3dB (7Hz-11Hz typical in-room extension)
CEA-2010 RATINGS
Ultra-low bass (20-31.5 Hz): 120.7dB
Low bass (40-63Hz): 132.1dB
*Subtract 9dB for an equivalent RMS 2m ground plane measurement distance.
DRIVERS
Two Power Sound Audio proprietary 18” drivers
Extended and vented pole geometry
Vented back plate to maximize air flow
Extremely linear and dynamic motor system
Epoxy reinforced cone neck/apex joint
Concentric foam surround, treated for longevity
Highly treated, rigid paper cone body
Die-cast rigid aluminum frame
Three inch diameter, four layer copper voice coil wound on a rigid multi-layer aluminum former with Kapton heat shielding
Fatigue limiting designed, silver alloy lead wires
Single poly cotton semi-progressive, high excursion spider
Paper outer dust cap with acrylic coating
Inner Mass Loading Cap that also strengthens the cone body
Assembled in the USA
AMPLIFIER SPECIFICATIONS
ICEpower® audio technology
Amplifier Power: 1700 watts
Inputs: Left and Right RCA inputs
On, Auto, Off selector
Gain control
Time delay(phase) control
Crossover control
Room size control
Custom DSP(digital signal processing) enables superior engineering refinement
CE and FCC approved; EMC and safety pre-approved
Fully integrated amplifier and power supply with mains-converter and auxiliary-converter
Patented HCOM modulation and control techniques for unparalleled audio accuracy
Sound optimized soft clipping
Soft start power up with mute/de-mute.
Thermal and over-current protection
Standby converter with low standby power consumption (less than 1 watt)
Universal mains operation (100-240 V, 50-60 Hz)
Standby power consumption 170 mW @ 230 V
ErP (1275/2008/EC) compliant
Energy Star®v3.0 compliant
117 dBA dynamic range
THD+N = 0.005 % @ 1 W (4 Ω, 1 kHz)
THD+N = 0.0008 % @ 50 W (4 Ω, 100 Hz)
CCIF IM distortion = 0.0003 %, 10 W, 4 Ω, 18.5 kHz / 1 kHz
High output current limit of 30 A
ENCLOSURE
Sealed enclosure
Dual opposed, side-firing drivers with grill covers
Super durable, black sand textured finish
Precision machined CNC panels for perfect fit of all components
Rigid MDF baffles
Dimensions (D x W x H): 51cm x 72cm x 61cm (20” x 28” x 24”) includes grill
Weight: 137 lbs
Made in the USA
Website back up and running properly now:)
We have an ex demo Yamaha RX-A3040 for sale. We will also have from tomorrow a trade in Yamaha A3040. Both boxed and with all original accessories, and good condition.
We have also listed our ex demo unit on ebay (more information here).
Contact us for more information.
-- As an eBay Associate, AVForums earns from qualifying purchases --
We will also have a ex demo Sony VPL-VW300ES available for sale soon (we will be changing to the VW320 or VW520 on release).
There is less than 200 hours on the bulb.
Contact us for more information, and to register your interest.
Our ex demo RX-A3040 has now been sold, but we still have a trade in A3040 for sale. This is listed on ebay here, at nearly 50% of the MSRP from just 12 months ago.
We have also listed our demo Sony VPL-VW300 4K 3D projector for sale on our website here. Mention that you are an AVForums member when contacting, and we will see if we can get you a bit more of a discount:)
We have started our annual projector rotation, meaning that we have now have the Sony VW520ES 4K projector and Epson LS10000 Laser projector on demo. 2015 JVC projector to be added once released.
Also added to the demo room, is some more 4K demo material, inc BT UHD, Netflix, and Amazon.
Before we received the VW520, we had the chance to bring in a VW320, and test before supplying to our customer. You can see the results of the testing in the attached pdf.
Some of early thoughts on the VW520 can be found in this thread. More information to come soon.
  • VPL-HW320 test.pdf
Dirac soon to be coming to an Atmos AVR....
The information has now been released to the public, and we can confirm that the new Arcam AVRs will feature:
Dirac Live EQ
seven HDMI 2.0a inputs with HDCP2.2
3 HDMI outs
Dolby Atmos
DTS:X via firmware upgrade
We will be getting one into our demo room, just as soon as we can....
Expected prices are £2400 (AV550), and £4,200 (AV850)...
We have arranged some new forum days. As can been in this thread. These will be used to showcase the new Arcam AVR and JVC Projector (pending their arrival), as well as existing kit i.e. Sony VW520ES, and Epson LS10000:)
We will also have a full 5.1 from Power Sound Audio this time too....
I thought I would make our followers aware that we currently have one brand new boxed Arcam AVR850 available for supply and install. Our time is getting booked up fairly quickly in the run up to Christmas, but there is still a little time if this is something you are interested in, before the next delivery in January...
With the install of every Arcam, we use a UMIK-1 calibrated microphone, and also can set custom curves depending on the user requirements.
We recently demoed a combination of the Arcam AVR550 and Power Sound Audio Speakers, and you can see some of the comments from some of the listeners in this thread here.
Not been here to update for a while, but have a few pieces that we are now moving on:
Power Sound Audio S1500 (ex demo), satin black with square edges. £999. More information here.
Lumagen 2143 4k Video Processor and Scaler. More information here.
We also have the Arcam AVR550 in stock at this time for install. When we install we can create custom targets, and supply a 1u amplifier to power the extra 4 channels for Atmos (if required). More information here.
We have a batch of HD Fury Integral on the way to us at the moment.
This 2x2 matrix unit has a number of benefits including:
- Being able to split audio from a video signal (useful when using a legacy HDMI amp with a 4K product i.e. Amazon Fire TV 4K.
- Being able to disable to disable HDR but keep Rec.2020 gamut from UHD Blurays.
- Allowing use of 2 x HDCP2.2 sources when only one HDCP socket on a TV.
We are offering a special AVForums Preorder deal on this first batch, so drop us an email ([email protected]) if you are looking to get a price.
It has been too long since I have updated this thread. We have had various things going on. I will revisit at some point, and add more information, but in the meantime. I can confirm we have the following special offers/trade-ins etc:
Trade ins:
Sony VPL-HW40ES (black) - £1,000
Epson TW4400 - £600
JVC DLA-X3W - £600
Sim 2 HT300 Link - £300
Ex demo
Yamaha RX-A3050 - £1,000
OPPO 103D - £400
New
We are pleased to announce the Epson TW7300, TW9300 and TW9300W have started shipping. Stock is erratic, but we have some stock, and stock is flowing through slowly.
We are also stocking the HD Fury Linker.
Just to add we also have a limited number of Epson LS10000 laser projector (New), which for £4,500 will be supplied with a HD Fury Linker, and pre shipping calibration.
Contact us for more info...
thanks guys for the speedy service sending out my zapittii mini 4k hdr thursday fantastic service
Been a while since I have posted in here, but we have a few things on special at the moment:
- We have a few open box items, including an OPPO UDP-203, UMIK-1, Integral (2016 version). Please contact us for more info.
- We have an ex demo anthem MRX-720, fully boxed with all original accessories. Contact us for pricing.
- We have a new batch of Crowson Technology Shadow-8 Dual Motion Actuators due in the UK in the next couple of days. Looking for some user reviews, so can offer some preferential pricing if you want to use and review.
- We are running an Epson based projector event where attendees are given the opportunity to win a TW7300. More info here.
- We have a few Zappiti NAS 8N at a slightly discounted price, due to a purchase discount. Contact us for more information.
- We have 3 x S1800 PSA subwoofers left in stock at a reduced price of £1,175 (down from £1,449), once they are gone, there will be no more.
We a lightly used JVC DLA-X5500BE X5500 in black for sale for only £3,250. Comes with 3yr JVC World UK Warranty.
It has less than 15 hours on the bulb, and has had custom profiles and HDR curves added. More information available here.
Hi @Rickyj @ Kalibrate - do you guys have any UMIK-1 mics in stock, and if yes what's the price please? Thanks
Afternoon, it has been a long time since I have posted on here, there is a lot that has happened, and will bring this section back up to date asap, but in the meantime, I thought we would bring some news to peoples attention:
Moved
We have moved and as part of the new demo room, we will be running Krix speakers, Trinnov Audio Processor, and Arcam Processor in a 9.1.6 pattern (using Krix/Procella speakers) + PSA Subwoofers.
Shipping
We are not installing at the moment, but are still shipping, with the JVC N series proving popular at the moment. All of which have experienced the Kalibrate preshipping setup. We also have access to various other stocks, so if you are after anything in particular, please drop us a message.
MiniDSP
We had a run on the miniDSP products in Feb/March which means we are completely sold out now (barring one 2x4 unbalanced). We hope to restock, but may not be for a while yet.
Ex Demo/Trade In/Refurbished stock
We have various bits of stock, that we are moving including the following:
- Optoma UHD65, low hours, boxed with original accessories.
- Sony VW260 (white), boxed with original accessories.
- Zappiti Mini HDR (refurbished)
- Parasound ZM450 small factor 4 channel power amlifier (used) x 2
- Atlantic Technology 44DA Dolby Atmos upfiring speakers - gloss black - new pair
- Murideo 6G HDR Pattern Generator - Ex demo with flight case, and power lead.
- Paradigm Millenia One Speakers (7 speakers - some black, some white).
- Emotiva BasX A100 - open box, but not used.
If you want any further information on the above, please message us.
Moved
Shipping
MiniDSP
- Sony VW260?
could be, ideas on cost?
- Sony VW260?
£1,499 for the UHD65
£2,350 for the VW260
Haven't got them all installed yet, but the ones that are installed sound very good. Dynamic, effortless sound as they, easy to drive ;)
We have 2 used projectors available at the moment.
One refurbished JVC N5 in white. Under 100 hours on bulb, full working condition, with original box and accessories. Will be set up before supply.
Trade in Epson LS10000. Pictures and more information coming soon.
Contact Us for more information.
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
