k750i video time
Discussion in 'Mobile Phones Forum' started by Hards, Aug 6, 2005.
  1. Hards
    Hards
    Jul 27, 2004
    10
    does any one know if the video time can be extended from the standard 10 seconds, cant find anything in the manual, thanks.
  2. po_man
    po_man
    Dec 23, 2004
    1,679
    St Albans
    +64
    YES! I'll start from the very beginning, just to try and avoid any confusion - Slide the camera cover open to active the digital camera/movie camera then select the movie camera mode (if it's not already selected). Click "Settings" and toggle across to "Shoot mode". Now simply select "High quality video" and this will enable you to shoot until you run out of memory!
