K750 Joystick problems ?
MonkeyDonkey
Anyone had problems with their k750 joystick ?
A few weeks ago mine didn't respond very well to down and took a bit of force to get it to go down, it then seemed ok, but now doesn't respond very well to up.
Anyone else found this ?
chrislad
I know that the main cause of problems with the 500 and the 700 is the joystick. It does tend to get a bit stuck. Since we don't have the 750i in stock yet, I can't comment on that, but I assume the same problems would occur, though less frequently.
chrislad
There's not really. Just get it sent away from repair. Sony Ericsson have a 24 month warranty on all phones bought after September (12 months before September) so you'll be covered.
MonkeyDonkey
Cheers.
I think i'll wait a week or so see if this works itself out like the problem with scrolling down did, if not i shall send it away.
Although, its only lasted 3 months, i'm not gonna be too happy about sending it away every 3 months if its gonna keep happening, brilliant phone apart from that though.
richcandy
Established Member
I had this problem on my K700. It was on a contract with T-Mobile. Went to the store and they sent it of to get fixed and was back in 3 days.
Rich
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
