k17s and k4s large or small
Discussion in 'Home Cinema Speakers' started by john R1, Nov 12, 2004.
  1. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    am using 3x k17s pair of k4s and a vx100 sub are you using your speakers set to large or small am feeding mine via a 3805 according to the auto calibration set up on the 3805 it has set them to large ?
  2. recruit
    recruit
    Hi John,
    I would never trust the Auto settings, when i ran mine on the Z9 it also gave me large speakers for the front with the M&K's they are sat's so i would say change them back to small so that the sub can handle the Bass and let the sats do everything alse above
    John
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    No M&K speaker officially drops below 80Hz so they should all be treated as small. It does sometimes seem a little odd that even the most expensive M&K, which is a fairly hefty piece of kit, isn't designed to reproduce below 80Hz
  4. recruit
    recruit
    Ian M&K do a range of speakers that do go below the 80hz.
    www.mksound.com/pdf/spec_sheets/spec_mains/MK_B1600_speaker_specsheet.pdf
    John
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Thanks John - I've never heard of them before. I'm intrigued to know what they sound like
  6. recruit
    recruit
    They are fairly new so i don't suppose too many people have, but i'm sure they must sound great :thumbsup: and now you have even more choice from there range.
    John
  7. recruit
    recruit
