Hi People,
First thing to say is love the picture. Second thing is to say I am not so loving about the bad switch on/switch off behaviour.
The set up:
Marantz SR6014 receiver connecting AppleTV, Oppo 205 Blu-Ray and JZ1000 all together. The issue I am seeing is that switching off sometimes works, and sometimes the set will switch back on again. Has taken up to 3 times to get it to finally switch off. The HDMI/Viera are set to switch off/on connected devices. Often when I have the switch off problem, when I switch the set back on, the receiver won't and has to be manually switched on. Then oftern the Sound has been set to TV rather than Home Cinema.
Very annoying and I suspect a fight between HDMI settings and Viera settings. Do I need both if none of the connected devices are Panasonic? If I turn if off, the AppleTV remote no longer functions and HDMI control is turned off.
Thoughts?
Andrew
The set up:
Thoughts?
Andrew
