steve k
Established Member
Is there a reason why JVC machines do not get much of a mention
It's almost certainly referring to RGB loopthrough and RGB Output on AV1 as opposed to RGB input.Why on some of the spec's it says dual scart (with RGB )
hornydragon said:If only they came in black..........
steve k said:Why on some of the spec's it says dual scart (with RGB ) this is on the new model JVC DR-MX1SEK have a look on the
What are the editing facillitys like on this machine can anyone tell me
Just looked at the instruction book and it has component out so wouldn't the scarts RGB be the input.
And what audio will it recored can it record 5.1
