JVC XV-522/523 Hack Needed
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by RMCF, Jan 7, 2001.
  1. RMCF
    RMCF
    Aug 24, 2000
    7,449
    +746
    Query for a friend:
    Is there a handset hack available for this machine?
  2. Pinkwillow1
    Pinkwillow1
    Hope this is helpful
    http://www.dvd-recordable.org/modules.php?op=modload&name=Reviews&file=index&req=showcontent&id=10
    JVC XV-522
    1) Make sure there is no disk in the tray.
    2) Unplug mains AC
    3) On the unit press and hold "play" and "open/close"
    4) While holding these keys plug in mains power
    5) Release these keys and test apears on the display
    6) Press "3D-phonic"
    7) Press menu twice on the remote
    8) Display reads 000 5858 use down buttons to 000 to 02e
    9) Change last 4 digits to the following
    0000 for region free
    0101 for region 1
    0202 for region 2
    10) Press enter on the remote
    11) Press standby and wait 5 seconds
    12) Press standby again and the player is now set to the region that u desire
  3. leonidasp
    leonidasp
    this doesn't work for 523... I tried and didn't work.. Is there another one for xv-523???????
  4. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    This will only work on early XV-522/523s. Later versions can't be hacked.
  5. Justin@UH
    [email protected]
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    No handset hack for this, only for the very first JVC models (before 1998). This can only be modded via either a chip or service tool from a multiregion modder.
