JVC X30 3D stopped working
Discussion in 'Projectors, Screens & Video Processors' started by Talgo, Feb 17, 2014.
  1. Talgo
    Talgo
    Oct 2, 2010
    609
    2
    46
    +122
    Last night I thought I would have a play with 3d .. I could not get the glasses to sync with the image .. This is with a SBS image from htpc with the x30 set to SBS mode. Its almost as if the rf emitter has stopped working. Can't remember the last time I used 3d but it worked then.
    Tried 2 different sets of glasses with no joy.
    Has anyone ever had a emmiter fail ?
    Its not the end of the world as I am not a 3d fan but would like to sort it out ...
    Should I do a reset of the x30 ? If so how
  2. GaryB
    GaryB
    Nov 12, 2002
    5,393
    St Albans
    +1,303
    You can see if your emitter is working by pointing a camera at it (a phone camera will do). They can see the IR and you should see a row of white/blue dots along the front of the emitter.
    If you want to do a full reset, you can do that in the Service Menu. Press Up, Down, Right, Left, OK in quick succession on the remote control. This should get you into the Service Menu. The reset option is at the bottom of the "Options" menu.
  3. Talgo
    Talgo
    Oct 2, 2010
    609
    2
    46
    +122
    Thanks Gary I will let you know how I get on
  4. Talgo
    Talgo
    Oct 2, 2010
    609
    2
    46
    +122
    All working now .. Good tip on the camera .. I think it was a combination of flat glasses .. New install of xbmc .. And me being an idiot !
