JVC-USB issues
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by psandbach, Jul 10, 2002.
  1. psandbach
    psandbach
    Hi there,
    I've just bought a JVC GR-DVL 365 digital camcorder and am having a few problems getting the contents of my memory card onto the PC. I install the USB drivers as suggested in the manual without connecting the camera to the computer, but when I do connect it, it re-installs the drivers. I think this is causing the removable disk icon not to be displayed which is a pain the butt as I cant connect.
    If anyone who has had similar problems could give me some advice I'd be eternally grateful!
    Pete
    :confused:
  2. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,114
    Leicester
    +48
    I've had the said same probs.
    It took me a second motherboard and a few re-installs to find out the answer.
    The answer for me was a card reader.
    Jessops told me they have had no probs with people using these.
    I used Jessops branded readers.
  3. Drafter
    Drafter
    I had the same problem and bought a Lexar card reader. The reader does work. I sent my GR-DV2000u back for repair and they can't fix it. I'll make a new thread on my repair problems.
  4. psandbach
    psandbach
    Sorted it!
    It was a pc problem rather than a camera problem.
    I looked in my config.sys and the "lastdrive=" line was set to F (which was my CDR drive). When I changed this setting to "lastdrive=Z", and restarted, it all seemed to work and my camera registered as drive G:
    If you want to edit config.sys, (be careful otherwise you'll end up in a whole world of poo!), in the start menu click "Run", and then type config.sys in the box.
    Hope all goes well with your problems...
    Pete
    :D
