JVC TU-DB1SK (freeview)
Discussion in 'Freeview & YouView' started by keef, Jan 14, 2005.
  1. keef
    keef
    Any body out there having problems with this box?
    Mine keeps going to standby, then not responding to the remote.
    Also switches on with blank screen, again no response to remote.
    Also lost some channels and needed a re-tune.
    A dealer has updated it to a later software version which seemed to cure it for about a week but now it is mis behaving again.
  2. phcahill
    phcahill
    Apr 11, 2005
    45
    Out of interest what software are you on?
    Mine says 2.2 and I keep getting audio dropouts.
    I'm showing top signal strength and the picture never breaks up.
    Paul
  3. bs77
    bs77
    Oct 21, 2005
    59
    i install av equiptment for a living and have had nothing but trouble with these boxes. There is a problem with them overheating which can lead to going into standby and none resposive to the remote. knocking of at the main for a few minutes generally cures it, but my advice would be replace it.
