Jvc Thsw8
Discussion in 'Home Cinema Buying & Building' started by nearly_down, Mar 22, 2005.
  1. nearly_down
    nearly_down
    Hi - I'm a newbie on this site. :hiya:
    I've just bought the JVC THSW8. I've only had it a few days and I'm very impressed. If anyone has any experience of this system good or bad please let me know.
    I've got my PS2 and SKY connected optically via a scart switch box, I just need another optical cable and a new av cable and I'll have my Xbox and Gamecube connected.
    I've gotta say GT4 is superb in 5.1/Pro Logic II.
  2. billt
    billt
    Hello
    I am considering buying the JVC TH-SW8 and would also be pleased to hear peoples opinions of the system. Does anyone know if audio CD playback is good.
    Thanks in advance if anyone can help
    :lease:
  3. krmuir
    krmuir
    Got one today. Considering taking it back already. Won't play in colour with either TV or projector - pretty useless in other words. It's a shame cos everything else about it is excellent - sound quality in particular.
    If anyone can help that would be great but I suspect my peripherals are too old
  4. GaryB
    GaryB
    Nov 12, 2002
    5,386
    St Albans
    +1,292
    It can output composite, S-Video and RGB, so it should work with just about anything. Suggest you switch it to composite output as a starting point, as just about any TV should work with that.
  5. krmuir
    krmuir
    Thank you, It was a cabling issue and it works fine now! I highly recommend this system
