Jvc Th-s9
Discussion in 'Home Cinema Buying & Building' started by Amarjit, Jul 29, 2004.
  1. Amarjit
    Amarjit
    Just obtained my newly aquired JVC TH-S9 all-in-one system yesterday, multiregion, for £350. In the manual, it mentions that a "System Chord" links the DVD player (or referred to as the "Center Unit" by the manual") to the "Powered subwoofer". From closer inspection the system chord is 8-pin. I intend not on using any cables supplied in the box, as I'm wanting to purchase a component lead, an RGB SCART and optical lead, so therefore unsurprisingly, is it possible to buy a decent version of this lead elsewhere?
  2. jmk
    jmk
    Sep 24, 2004
    9
    Hi Amarjit - i'm thinking of getting the th-s9. How has it worked out for you? Is the sound quality good for regular stereo music? Any advice?
