JVC th-s51. Can you hack this?????????
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by lenw, Aug 20, 2005.
  1. lenw
    lenw
    I have a JVC TH-S51 theatre system but can only play region 2 DVD's.
    Is there any way to change this myself, or can it only be chipped?
    Thanks.
  2. Justin@UH
    [email protected]
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    Sorry, no handset hacks for JVC systems or recorders (as posted here before!). If you didn`t buy it pre-modified from a specialist dealer, then your only option is to use one of the modification services (found via a google search, or via the forum banner below) to make your machine multiregion.
    There are no built in handset hacks for this or other JVC models:(
