JVC Sub-woofer trouble - have I checked everything I can?
Discussion in 'Subwoofers' started by itorres, Dec 13, 2002.
  1. itorres
    itorres
    Have JVC SX-PW22 power sub-woofer (connected to JVC RX-3THBK amp)
    - no sound comes from my sub-woofer
    - Sub-woofer been working fine for few years, although it blew its fuse couple of times at beginning. replaced it with ones included in the package and kept working fine.
    - speaker cable connections are correct
    - led on the sub-woofer power amp comes on. it's green as it should. it acivates automatically on the auto mode or manually too, if I choose it. so fuse is ok and power is good
    - when power amp on sub-woofer activates I hear a slight thud as usual through the speaker, so it seems speaker works.
    - adjusted speaker volume to max and switched crossover frequency to see if it made a difference, no change
    so, I think there may be something wrong with the crossover circuitry and not diverting any signal to the speaker.
    am I missing something to try before spending the big $ at the repair shop?
    thanks, all!
    Ivan
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,620
    United Kingdom
    +2,218
    What speaker settings have you selected on the amplifier, Large/Small? And what mode are you testing the sub in, Stereo, Dolby 5.1?
  3. itorres
    itorres
    I have tried all combinations I think.
    This Receiver has Surround On/Off
    Surround Mode - Prologic/3CHLogic/Hall (I use Prologic - for Front, Center and Rear speakers)
    Center Channel Mode - Normal, Wide, Phantom (Normal routes bass to front speakers which go to sub-woofer first)
    Another setting creating different Eq and Delay called SEA - Sound Effect Amplifier
    I don't have a setting for Large/Small, but I assume it sets if you have woofers in your front speakers so as to route the bass differently. I think that is controlled by the center setting on mine.
    Thanks for the help.
