JVC QP-F10 vs Denon DHT-1356XP
Discussion in 'Home Cinema Buying & Building' started by luoxy, Mar 14, 2006.
  1. luoxy
    luoxy
    JVC QP-F10 link http://www.jvc-asia.com/sg/products/...ails.asp?id=53
    Denon DHT-1356XP, link http://www.denon.co.uk/site/frames_m...ain=prod&sub=1
    Which package should i go with? Here is the dilemma, The JVC set has a better AVR (RX-F10 vs AVR1306), But Denon's sat speakers are better than JVCs by the looks of it. The JVC sat speakers look really cheap, don't they? details specification http://jsp.jvc-europe.com/files/inst...a52e08e674d d
    RX-F10: digital, componont video connection, stylish, 100w x 5 at 6ohms
    AVR1306: analog, bulky, consumes 2 times more electricity, 110w x 5 at 6ohms, looks like a scale down version of 1706.
    JVC sat: 1 way, 0.5/0.6Kg
    Denon sat: 2 way 1.2/1.4Kg
    JVC set come with a DVDP, but its cost more than Denon. The extra could probably get me another DVDP. Therefore the cost is probably not an issue here. I do get down to the shop and listen to both of system, the Denon set sounds better but again the two sets are place at different environment and it is hard to tell without a side by side comparison.
    I can't get the yamaha AV57 becoz its not available in my place, singapore. :(
  2. THERAAAVEN
    THERAAAVEN
    Jan 31, 2006
    587
    ruislip
    +10
    Denon Beats The Jvc No Question!
  3. luoxy
    luoxy
    thx THERAAAVEn, you reinforce my decision of getting the Denon!!
