Jvc - Qp Es3
Discussion in 'Home Cinema Buying & Building' started by cloudchaser, Jul 26, 2003.
  1. cloudchaser
    cloudchaser
    May 17, 2003
    83
    London
    +8
    Hi all
    First post from a newbie just about to enter the world of home cinema so please be gentle ; )
    I am finally taking the plunge and getting my first all in one system. Some of my requirements are -
    - component video ( plan to buy a Toshiba 36ZP38 later)
    - good enough sound to listen to CDs and normal music
    - play formats like - DVD-Video, DVD-R, CD, SVCD/VCD, CD-R/RW, MP3 (CD-R/RW), Digital Still (JPEG on CD-R/RW)
    - Multi-region --- ideally no complicated hacks via remote
    - should have looks good enough for the missus to approve ;)
    - Budget around £700
    Since looks were important I and the missus went around to the the local Currys to have a look and listen.
    We liked the sound of the JVC QP-ES3 (£699) which qualified on the sound and looks test. The salesmand as usual could not help with more details so I looked around on the JVC site for its specs.
    But there is no mention of it anywhere on the site. I did fine some others which were numbered similarly to the QP-ES code -- http://www.jvc.co.uk/product-list.php?id=15
    What I need to know if the QP-ES3 is a discontinued/old model?
    Are the other systems on the JVC site newer and better than the QP ES3?
    Also did a quick look around but did not find an reviews for the QP ES3. Does anyone know about this system and if its any good.
    Alternatively any suggestions for a system that could match my requirements.
    All help and tips appreciated in advance
    cheers
    cloudchaser
  2. GaryB
    GaryB
    Nov 12, 2002
    5,381
    St Albans
    +1,292
    The QP-ES3 is sold by Dixons/Currys only. The other models are generally available.
