JVC picture gone weird
Discussion in 'TVs' started by BILKO1, Apr 13, 2005.
  1. BILKO1
    BILKO1
    Apr 13, 2005
    43
    11
    Poole, Dorset
    +4
    Turned on my JVC AV-32r25eksc today and the picture is all discoloured around the edges the part of the picture that is ok is almost circular now. Is this something that i can fix in the service menu or do i need to get someone in as the set is a few months out of warranty. Not to impressed for a £750 tv, i bought it on Barclaycard thinking that the warranty would be extended but when i ring them up "sorry sir that service was stopped on 1st April 2005" grrrrrrrrrrrrrr.
  2. Matt123
    Matt123
    I'm no expert but it sounds like the tube has gone? Someone will correct me I'm sure :(
  3. JayCee
    JayCee
    Jan 20, 2004
    20,229
    Lanarkshire
    +1,937
    It sounds as though there is a fault in the degauss circuit........it's unlikely to be the crt.
    It could be a dry joint.......on........or a faulty "Ptc".
    This is the part which degausses or de-magnetises the crt at switch-on.
    Best to call in a local Tv engineer.......should'nt be too expensive.
  4. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    First to make sure of is that you don't have any strong magnets (like speakers) nearby.
    Next thing to try is the internal degauss circuit. Switch the set off at the mains (not just to standby) for a couple of hours, then switch it back on. This will fire the internal degaussing circuit (assuming it's working) and possibly clear the problem. If it doesn't, JayCee's suggestion of a faulty degauss circuit is probably correct. If it is only a couple of months outside warranty, JVC may well cover it.
  5. BILKO1
    BILKO1
    Apr 13, 2005
    43
    11
    Poole, Dorset
    +4
    Thanks for the replies guys i did what GaryB said and all seems well? The distortion was as if the internal side speakers had lost there shielding i have no other speakers / magnets near the tv. Thanks guys:)
