JVC Panoramic Mode
Discussion in 'Plasma TVs Forum' started by Shady Deal, Nov 9, 2003.
  1. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    Just bought a 42" JVC Plasma and am basically very happy with it. However when viewing the picture in Panoramic mode each side of the screen is stretched outwards. This is especially noticable when text moves across the screen as it starts big at the edges and is the right size in the centre before going big again at the other edge.
    The manual says this mode will stretch the picture but not to make it unnatural??
    Can anyone confirm what I see is normal for this type of TV/Screen setting??
    Mark
  2. bossc@
    bossc@
    Dec 20, 2001
    1,160
    +268
    The Hitachi 42PD3000 does this too. Rather than strech the whole image, just either side is, with the centre remaining the same. I believe that certain manufacturers think that the viewer will be more concerned with the action which is generally centred so you wouldn't notice the sides being stretched. Doesn't really work that way though does it, and once noticed then you cant take your eyes off it:rolleyes:
    I dont know about the other manufaturers though.
