JVC or Philips
Discussion in 'General TV Discussions Forum' started by richdgrant, Aug 20, 2002.
  1. richdgrant
    richdgrant
    I have been looking for a widescreen tv on a tight budget for a while now and I'm not sure if I should get the JVC AV-28CT1EKS or the PHILIPS 28PW6006. Could someone please tell me which they would recommend. Thanks.
  2. chegz60
    chegz60
    Comet have Philips 28PW6515 on offer at £459 free delivery if ordered on net.:)
  3. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
  4. jpwhaley
    jpwhaley
    Feb 1, 2002
    44
    Bristol
    Just returned two seperate Philips 28PW6006 TV's. They are great TV's, good colours & geometry but I had the ghosting & faint vertical bar issues when using RGB in. Do a search on these forums for more info.
    I also did extensive testing of the JVC and the only issues was the menu interface for changing aspect ratio is combersum. Have a play first at a shop before ordering.
    In the end I picked up an Curry's Manger's Special: A Panasonic TX28PK3 for 199GBP due to a dent in the case!
