Jvc Lt42dv8bj
Discussion in 'LCD & LED LCD TVs Forum' started by kedge, Sep 18, 2007.
Tags:
  1. kedge
    kedge
    Jun 8, 2007
    1,789
    Rochester
    +73
    Thinking of getting this set Jvc LT42DV8BJ in replacement of my faulty LE40M87 due to the freeview judder.
    Can anyone with it tell me what blu ray plays like on it using the ps3?
    The samsung does 24ps so i didn't notice any judder but don't want to get a set that i have problems with.
    Any reviews anywhere?
  2. kedge
    kedge
    Jun 8, 2007
    1,789
    Rochester
    +73
    Just read the contrast ratio 1000:1 where the samsung is 15000:1
    Will this really make a big difference?
  3. Full Throttle
    Full Throttle
    15000:1 contrast ratio is a "Dynamic contrast" ratio, so do not let that number fool you. Expert forumities will explain this I am sure....
  4. kedge
    kedge
    Jun 8, 2007
    1,789
    Rochester
    +73
    Yeah but it still sounds low, the tosh x series i think was 6000:1.
  5. peahead
    peahead
    Dec 14, 2002
    3,139
    St.helens
    +447
    Yes the tosh is quoted as 6000:1 but that is also a dynamic ratio its prob more like 1000:1./ 1200:1.
    Why not hold out for the new toshiba z model due out soon or give the jvc a shot.
  6. c3ham
    c3ham
    Sep 29, 2004
    203
    +19
  7. kedge
    kedge
    Jun 8, 2007
    1,789
    Rochester
    +73
    Well I have taken a chance, the Samsung will be replaced tomorrow by the Jvc.
    Really hope I have a problem free set this time around, otherwise :suicide:
  8. peahead
    peahead
    Dec 14, 2002
    3,139
    St.helens
    +447
  9. c3ham
    c3ham
    Sep 29, 2004
    203
    +19
    Hi kedge
    What you initial thoughts on your new tv?
  10. kedge
    kedge
    Jun 8, 2007
    1,789
    Rochester
    +73
    Well I received the Jvc lcd today and 1st impressions it is really good, haven't played about with any settings yet but I must say the sound for a lcd is top notch with plenty of bass and treble.
    Think it does have slight bleeding in the top left corner but will look into it more later.
  11. c3ham
    c3ham
    Sep 29, 2004
    203
    +19
    cool
    you should try soft warm picture setting for watching movies gives you close to d65 colour temp and better black levels worth a try you may like:)
  12. kedge
    kedge
    Jun 8, 2007
    1,789
    Rochester
    +73
    Another update:
    Sound level far better than samsung
    Freeview picture much better with no judder
    No 24fps but blu ray and hd playback is smooth
    Does have slight light bleeding in from top left of screen (not that bad)
    Bulid quality is far better than samsung.
    I prefer the look of the samsung screen (the reflective glass look)
    Not sure on the black levels yet compared to the samy.
    Like to test out the samy 100hz model now to compare..
    Packaging on the samsung was better, you have to lift the screen completely out of the jvc box.
  13. peahead
    peahead
    Dec 14, 2002
    3,139
    St.helens
    +447
    Thats a really nice setup kedge looks very smart can you tell me if the tvs vga/component input will take a 1080p signal from the xbox 360.
  14. c3ham
    c3ham
    Sep 29, 2004
    203
    +19
    hi
    not sure about vga but the component input does not accept 1080p
  15. kedge
    kedge
    Jun 8, 2007
    1,789
    Rochester
    +73
    I haven't a vga cable to try matey, sorry.
