JVC LT37DS6 dimensions
Discussion in 'LCD & LED LCD TVs Forum' started by bassman92, Aug 24, 2005.
Tags:
  1. bassman92
    bassman92
    hello all :hiya:
    Having seen the 32DS6 and almost decided it's the set for me, when looking at where the set is to go I may get the 37 inch version in. Anybody got one and can tell me the dimensions?. The height isn't a problem but the width is and I cant find any website with it on!
    Al
  2. dicko17
    dicko17
    I Asked Jvc The Same Question By Email 6 Weeks Ago , They Replied Yersterday , They Lost My Custom I Purchased A Panasonic 37" Plasma Instead , And Its Perfect.
    Anyway Its 930mm Width.
  3. bassman92
    bassman92
    Thanks for that. I'll go and measure up. I do wonder why manufacturers can't reply to simople requests from prospective customers tho!
    Al
  4. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    Just in case it's a tight fit, it's actually 925mm wide.
  5. rhubarbe
    rhubarbe
    May 25, 2005
    4,675
    Cheshire
    +211
    I was looking that that 32" JVC, wanted a manual and had to phone then because it isn't on any of their web sites (I found it since, no thanks to them, on a forum).
    The support staff were offhand to the point of rudeness, not understanding why I would need a manual if I didn't have the TV: oh what a simple world we used to live in.
    Anyway, I crossed it off my list because lousy srivice to a prospective customer tends to translate into no service at all once you've bought the thing.
  6. neilmcl
    neilmcl
    Oct 29, 2004
    6,236
    103
    Nottingham
    +292
    Well if you want to be really accurate it's 926mm wide x 689.5 x 297 ;)
  7. bassman92
    bassman92
    Thanks for the dimensions chaps but pity it's just too big...have to be a 32 inch set then :smashin:
    Al
  8. julianjgeorge
    julianjgeorge
    Hi, just double checking!! Are these the external dimensions for the LT32DS6 or the JVC LT-37DS6 hope its the 37" as I can squeeze this in!
    Thanks.
    JG
