JVC LT26DS6 Owner Opinion
Discussion in 'LCD & LED LCD TVs Forum' started by stu.artd, Aug 14, 2005.
Tags:
  1. stu.artd
    stu.artd
    Jul 29, 2005
    3,886
    +327
    I'm thinking of a JVC LT26DS6, but wonder if the PC input allows the display to be driven at (or near) the full res of 1366x768 ?
    I know the LG 26LX2R does, but that set is too wide.
  2. peahead
    peahead
    Dec 14, 2002
    2,996
    St.helens
    +384
    I believe the jvc does not show pc input at native res but at the lower 1024x768 res dont know about the lg yet.
  3. msg
    msg
    May 20, 2005
    458
    Darlington
    +10
    Your graphics card must be capable of outputting 1366 x 768 otherwise the image will be stretched/shrunk to fill the screen.
  4. stu.artd
    stu.artd
    Jul 29, 2005
    3,886
    +327
    I have a Radeon X800 XT and it can output at 1360x768.
    So the JVC will definitely show this properly at 1360x768 ?
    I need to know for sure as the JVC LT26D50 only appears to support 1024x768 and 640x480 from a PC.
    If the JVC LT26DS6 can't support 1360x768 from my PC via VGA then that's another one I can cross off my list.
  5. GaryB
    GaryB
    Nov 12, 2002
    5,386
    St Albans
    +1,292
  6. stu.artd
    stu.artd
    Jul 29, 2005
    3,886
    +327
    Thanks for that info and the file Gary, looks like I won't be going for the JVC. :(
    Why does this choice have to be so difficult ?
  7. msg
    msg
    May 20, 2005
    458
    Darlington
    +10
    I fed 1024 x 768 into one of these TV's and it did not display correct resolution, but stretched the image to fill the screen.
  8. jamesf303
    jamesf303
    Apr 7, 2005
    83
    +5
    Hi folks,
    I have read the manual and it does indeed state that this TV only does 640x480 and 1024x768 via the VGA port but has anyone actually tried a resolution near its native (i.e. 1360x768 or 1368x768)? Its possible to create these resolutions using powerstrip on windows PCs or using the correct linux modeline. I would be great if this is possible and would seal a purchase for me...
    Alternatively, has anyone tried the above resolutions via DVI using a DVI to HDMI adaptor? I have head that HDMI inputs are usually overscanned. According to posters in these forums this is definitely the case with the toshibe 27WL56.
    Thanks in advance...
  9. MDPlatts
    MDPlatts
    Aug 20, 2005
    276
    2nd City - Manchester, UK
    +21
    they say the same about the 37"er too - but it supports the full 1366x768 fine.
  10. jamesf303
    jamesf303
    Apr 7, 2005
    83
    +5
    Thanks MDPlatts.
    Has anyone got this to work on the 26" model?
    Unfortunately neither my lounge or budget is big enough for 37" :D
  11. Eiji
    Eiji
    Feb 16, 2005
    1,422
    48
    +69
    The problem is most, if not all PC graphics cards only output resolutions at multiples of 8 and 1366 isn't a multiple of 8 whereas 1360 and 1368 are.
    Thats why people either set their desktops at 1360x768 or 1368x768 or look for a LCD with 1:1 pixel mapping and output at 1360x768.
