JVC LT-37DM6 - whats this one?
Discussion in 'LCD & LED LCD TVs Forum' started by richard plumb, Aug 9, 2005.
Tags:
  1. richard plumb
    richard plumb
    Jan 27, 2002
    14,450
    Windsor
    +1,044
    Seen all the positive comments about the DS6, and the 37" is about £1700, includes freeview etc.
    Noticed this one - 37DM6, at around £2100-2400. Whats the difference? I thought the DS6 was the latest one?
  2. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +122
    Additional memory card reader - that's all.
    Save the difference and get something like the Samsung HD850/950 or blow the difference on Marantz 7600, both of which will upscale the DVD to 720p or 1080i. Will make them look a little bit better than they already on your current CRT TV.
  3. dicko17
    dicko17
    According To The New Jvc Catalogue The Lt-37dm6 Is Described As "super Deluxe Lcd Idtv Equipped With Fast Response Lcd Panel Driver" Whereas The Lt-37ds6 Is Described As Just "deluxe Lcd Idtv" .
    I'm Presuming From This Description That The M Has Got The Much Better Screen , Which Would Make Sense Seeing As Its Approx £400-£500 Extra , I Can't Just See The Extra Dosh Being Just For A Card Reader.
  4. neilmcl
    neilmcl
    Oct 29, 2004
    6,224
    103
    Nottingham
    +289
    I got an email reply back from JVC UK and this is what they said:
    "Thank you for your inquiry. These two units are indentical in specification
    but LT-37DM6 has a Multi memory card slot as an additional feature, that's
    all"
    A lot of money to spend for a MM card slot then!
