JVC LT-26DS6 Or Sagem L27
Discussion in 'LCD & LED LCD TVs Forum' started by Theresa, Jun 28, 2005.
Tags:
  1. Theresa
    Theresa
    I am now going to go for a 26inch screen, for the bedroom TV,which is about the same money is the 23 inch Sony (and that wasn't HD ready).
    So I am down to these two and guys what would you choose? The reviews aren't from the same source.
    JVC LT-25DS6
    I can't find any reviews for this maybe it is too new. Saw it in Currys yesterday and analogue picture looked respectable but git wouldn't put on a DVD
    Price (online) about £1050
    Here is the spec
    2 SCARTs
    S-In, AV-In
    W-XGA (1366 x 768 pixels)
    IDTV (Integrated Digital TV Receiver)
    Slim-line Design
    HDMI Connection
    HD Ready
    D.I.S.T. (Digital Image Scaling Technology) for High-resolution Picture
    Core components: High precision I-P Converter and Formatter
    Supporting components: Super DigiPure, IC with dedicated 32-bit CPU to process Dynamic Picture Management, Colour Management, Dynamic Black Level Control and Gamma Curve Control
    1-tuner PAP (Picture and Picture)
    12 Multi-picture
    Picture & Text Dual Screen
    Front 2 Oblique Cone speakers
    3D Sound
    AHB (Active Hyper Bass)
    BBE(R) Sound System
    Component Input
    PC Input
    Sagem HD-L27
    Price (online) about £850
    Anti-reflection coating and high viewing angle 160 degrees (hor and vert)
    PIP / PAP OC functions
    VGA/DVI and other video sources
    Integrated speakers 2 x 12w RMS
    Automatic sound volume control
    4 sound modesl, including Virtual Dolby Surround Sound
    Capability of up to 6 TV peripherals to be connected simultaneously
    5 video inputs, 2 PC inputs
    1 analogue VGA and one digital DVI with HDCP control
    Auto detection of video sources and formating of TV peripherals
    Integrated power supply and tuner
    Integrated photo card reader
    Slide show previewing
    Ability to rotate image through 90 degrees
    720-line display in progressive mode 720p
    The JVC is HDMI and the Sagem DVI
    I need PC Input
    I am leaning towards to JVC.
    Thanks!
    Theresa
  2. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
  3. Theresa
    Theresa
    :oops: I hadn't.
