JVC LT-17E31 Stuck in Standby
Discussion in 'Plasma TVs Forum' started by calluml, May 31, 2004.
  1. calluml
    calluml
    Apr 25, 2002
    16
    Edinburgh
    I've had one of these TV's since February and have had the "stuck in standby" problem increasingly, in the last few weeks. When this happens, attempts to switch the TV on from standby, using remote or button on the side, fail. Usually a disconnect/reconnect of the power will get things going again. Now thinking of sending it back.
    The TV is connected only to a SKY minibox, so no complicated setup.
    Anyone else out there with experience of this issue?
  2. Martijnvt
    Martijnvt
    I Have the same problem. After waiting a while it unlocks and startsup.
    Have you found any solution yet?
  3. calluml
    calluml
    Apr 25, 2002
    16
    Edinburgh
    After deciding this wasn't acceptable, I sent it back to supplier for repair. Took a week or two to come back, but has been working perfectly since then.
    If your one is still new, I'd get it fixed/replaced. It definitely is a problem.
  4. Martijnvt
    Martijnvt
    It is still new and I agree this is not acceptable. I will return it as well.
    THNX
    M
