JVC LCD range
Discussion in 'LCD & LED LCD TVs Forum' started by mark88, Oct 26, 2004.
Tags:
  1. mark88
    mark88
    Oct 25, 2004
    878
    +23
    Is anyone familiar with the JVC range of LCD panels who can help me understand the differences between models.....?
    http://www.jvc.co.uk/product-list.php?id=100088
    The difference between the LT-26C31, LT-26D50BJ & the LT-26C31S?
    The difference between the LT-23E31, LT-23C50BJ & the LT-23D50BK?
    It's not made clear at all. I know D50's have IDTV but other than that I'm clueless
  2. dbeacock
    dbeacock
    I've got exactly the same problem, I'm trying to get the full spec on these models as well.
    From what I've gathered so far one difference is the resolution: the LT23E31 has a res of 1280x768 and the LT23D50BK and LT23C50BJ have a res of 1366x768, so I think the "31" or "50" part denotes the resolution. The "C" and "D", as you mentioned, are without a digital tuner and with a digital tuner respectively. God knows what the "E" means.
    And as for the rest, well, I know what BJ usually means..... :zonked: :D
