JVC LCD problems
Discussion in 'LCD & LED LCD TVs' started by elmbeck, May 14, 2005.
  1. elmbeck
    elmbeck
    Sep 23, 2002
    347
    Avonbridge
    +10
    I have a JVC 26 inch LCD (about 14 months old) that has developed a problem with the screen. There are 2 visible lines that appear horizontal, approx. 3 inches and 8 inches from the bottom of the screen. Difficult to describe, but they are not sharp lines.... they are "fuzzy" lines that are about 1 inch deep.
    I'm just out of the manufacturer warranty (surprise surprise) but have an extended warranty through my Credit Card.
    Anyone any ideas what the problem is likely to be - I thought it may be inteference from Wireless stuff through my house, but turning them off made no difference.
    Cheers!
  2. GaryB
    GaryB
    Nov 12, 2002
    5,345
    St Albans
    +1,266
    From your description, it sounds like a couple of the backlights behind the screen may have gone slightly low. These can be replaced by an engineer.
